Arlo Go - Periodic Off-Line
  • 6 Replies
  • 5968 Views
sahnyc
Modem Version ARLO.FX.0.6.5.18.AM.001 Firmware 1.096.3.0_1.8.57.0_18 Arlo Service Plan For the past 2-days, the camera has periodically going off-line. The camera is used indoors with the AC adaptor and battery installed. I have contacted tech support, I was instructed to remove the battery & sim card and disconnect the AC adapter, then wait 1 min. I then put it all back together and after a few seconds the camera came on line. But, then several hours later it went off line again, only to back online a half hour later - as of right now it is still back online. Does anyone know what is going on here??
6 REPLIES 6
sahnyc
P.S:  I put it back together without the battery - I have it powered just with the AC adaptor.
Streak2
Master Master
Sadly I have been having the same issue. Just battery powered.
Seems that the cellular signal in my area has been quite variable in the past week or so.
Just today it appears to have stayed online the whole day.
Mdterps
I have had an Arlo Go for about a year and a half and it had been perfect up until a few days ago. Now it is offline more than online. I think a recent firmware has caused these issues.
sahnyc
Thanks for your reply  - appreciate it.
sahnyc
I was in my second contact with tech support that a Firmware update was mentioned.  I asked why there was no notification to customers/subscribers.  All I got was repeated appologies.  I told them these camers are used for security and if there is going to ber down time due to updates or maintenance then we need to get advanced notifications (email, account postings).
It was after spending 45 min with them going through resets/restarts that I was informed about the Firmware update,  the tech even asked what the current firmware #'s were at the begining of the contact.
River-rose
I have an Arlo Go Firmware1.096.3.0_1.8.57.0_0.6.5.18.AM.001. Model #ARLO.FX.0.6.5.18.AM.001  I have also had many issues with it claiming it is off-line yet still recording. It comes and goes.  In addition, it has become overly sensitive (and I have dialed down the sensitivity to under 50%) and so under windy conditions, like today, I am getting recordings every 3- 8 minutes.  Needless to say, it used up 30 min of recording time in one afternoon.  I had this problem last month as well (does not happen every day even if it is busy).  As noted in other comments, these problems all started recently with firmware updates.  I use this to protect my property, and problems usually occur in the afternoon, unfortunately when the wind comes up.  Hate to disarm it but that is what I had to do.
  • 6 Replies
  • 5969 Views
