I have several of the Arlo Go's that won't complete the start up phase. I put the battery in and a blue light will blink slowly indefinitely. I have removed the SIM card and inserted the battery and it will give me the audible error and solid orange light. Then when I re-insert the SIM it goes back to blinking blue indefinitely. Is this a result of a bad firmware update? Any way I can resolve the issue?
Are these new installs or existing? If new, are you following the setup procedure in the app or web client? Which cell provider? Have you verified the SIMs with the provider?
These are existing installs. I have tried both mobile and web. Provider is Verizon and the SIMs are correct and active.
Can you take one camera to another location with better signal for testing? I suppose resetting a camera to see if that helps may be useful.
Yes I've tried this with a couple of the field techs and no changes. Deleting the camera and re-adding it yielded no results.
Eric_G,
Can you provide exact details on what happens as you're going through the initial setup steps? What errors are seen?
Have you tried factory resetting as described here: https://kb.arlo.com/1202749/How-do-I-reset-my-Arlo-Go-camera-to-factory-default-settings
Modes et règles
