Arlo Go Keeps Being Disconnected
  • 2 Replies
  • 2452 Views
Vonnyal
The v SIM in my arlo go camera keeps getting disconnected by vodafone. Has anyone else had this problem? I have contacted vodafone many times about it and they can't tell me why this is happening!  Also does anyone know how much data the arlo go camera uses?
ShayneS
Have you tried to remove & re-sync your Arlo Go Camera? I have attached a data usage KB that may help. How much bandwidth and storage space do Arlo videos use?
Vonnyal
When the v-sim is deactivated I can't re sync it with the camera. I ended up buying a new v-sim which is currently working but early days yet to see if this stops the probelk reoccurring.  I was wondering if it was the amount of data it was using but there is only one price plan for this product so I can't change it.
  • 2 Replies
  • 2452 Views
