  • 5 Replies
  • 2041 Views
Lawtonwood
I have 4 Arlo Go cameras served by the Verizon Network.  I have unlimited Data and this is not the issue.  I have owned the cameras for around 6 months.  I had no issues with them going offline until the last month or so.   I have 3 of 4 cameras going offline consistently, usually just minutes after they connect to the network.  Then I have to reboot and it happens all over again.  Sometimes they stay online for 5 min, or a couple hours, to a day.  No rhyme or reason to it.  They are in the same locations as they have been since I purchased, and I have tried to switch around the cameras to see if this helped.  Batteries are charged.  Strong cell service in all locations, at least 3 bars at all times.
Any suggestions on what to try?
5 REPLIES 5
ShayneS
Lawtonwood,
What firmware versions are your cameras on? I have attached the firmware release notes here for reference - Firmware
Lawtonwood
1.096.3.0_1.8.56.0_4
It is an Arlo Go Verizon Wireless, I thought the firmware updated automatically?
ShayneS
Do you have ease of access to these cameras?
Lawtonwood
Yes I do
ShayneS
Lawtonwood,
Have you tried to remove and insert the sim card and reboot?
  • 5 Replies
  • 2042 Views
