I have 8 Arlo Go cameras in various positions around a field. Two of them are always going offline. I've changed their positions, cleaned the sim cards, done factory resets, put them in the same positions as other cameras but still they go offline. Any suggestions would be most appreciated. Thank you.
Best answers
An update is now starting to roll out for Arlo Go users who experienced offline issues with their camera. We expect it to reach all Arlo Go cameras in the coming week. Users may need to reboot (remove/re-insert the battery) and recharge the battery to receive the update, if your camera is already back online, no further interaction is necessary.
Additionally, we would like to clarify that this issue was not related to the 3G shutdown that has occurred on some carrier networks.Thanks for your patience and understanding. We'll continue to closely monitor your feedback to ensure your issue has been resolved.
Team Arlo -
Arlo is actively working with carriers to identify all the variables that could be contributing to this issue. It is a high priority for Arlo.
Thank you for the feedback & continued patience while we work to resolve this issue. We are actively working with our partner at AT&T to troubleshoot the situation.
Also, the solar panels work perfectly and keep them recharged to 100% every day!
Do Reolink cameras work with AT&T.
What cellular plan do you use? I did not see AT&T on the Reolink website. I figured I would have to use T-Mobile
I had ATT service on multiple devices for over 20 years. The ATT service area coverage changes for reasons unknown to the support agents and they can't do anything about it anyway. ATT support is totally pathetic and I switched all of my devices (8) to T mobile 6 months ago. Only mt Arlo go's remain due to being carrier specific. You can't beat T mobile support and for now 5G service, although that's irrelevant to our Arlo problem. The Arlo app. had an update in December, another 3 days ago.....but nothing is improving.
I highly recommend Reolink with T-Mobile!
I am having the same issue. Started about 2 weeks ago. Has worked well for years.
I got a call today from our security guy that they need to replace the cellular modem for our alarm system. He said AT&T is doing away with 3G/4G. They have to put in one that is LTE.
Anyone think that could that be the issue? Is the older Arlo Go compatible with LTE?
Thanks, Superwa1. I hope this issue gets resolved quickly.
Any recommendations for other systems that can replace this, unreliable, one?
@Superwa wrote:
They are only shutting down 3G, not 4G.
There is a network mode in the Go (not the Go 2) where you can select 3G network modes. If you do have access to the camera, it'd be best to set that to "LTE only".
@dasmaster wrote:
Specifically , when you click LTE only, it reverts back to “auto” as soon as you leave the screen. You can’t force it to do LTE only on the AT&T model unfortunately.
Ok. Definitely don't set it to the other two modes though.
Both of my Arlo Go cameras show "Your Arlo Device appears to be offline." in the app. However, they still detect motion and record video. If I close/re-open the app multiple times, they will eventually connect and be back online for a short period of time. I have deleted/re-installed the app, logged out and back in, and checked for firmware update. Nothing seems to help.
Modes et règles
