  • 27 Replies
  • 136877 Views
  • 3 Likes
  • 8 In Conversation
MP-AUS
Good day all,
Any one aware where to buy Arlo Go from in Australia?. Telstra is not aware as the Go has their logo on it. Cheers M
27 REPLIES 27
MP-AUS,
Take a look here for more information: Arlo Go Mobile HD Security Camera for Telstra
MP-AUS
Thanks JamesC,
I have sen that but not sure where to buy it from, maybe i missed it.
cheers
Mp
amachon
JamesC can you put a bit more effort in to your job. Refering to a link that is wrong is pretty lame. There is no reference to the Arlo GO on the Telstra site. Maybe you should have let telstra know before advertising it.
And why make these products exclusive, thats just dumb.
amachon
I purchases one from Amazon 3 months ago and used a Telstra sim with a Solar Panel from amazon as well and it works great.
MP-AUS
Thank you for the info, could you please let me know what was the approx price?  there is one for 430 $. Good to know the US go can be used with telstra sim. Cheers.
Kenski13
I have just purchesed the Arlo GO with sola panel from Amazon all looks good but having trouble with the telstra sim any help would be Awsome !!!
Kenski13,
Which model Arlo Go did you purchase? On the box, you should see a product SKU ( VML4030-100NAS for example).
Icey
Hi James,
Can you please let me know what SKU I should be looking to buy?
Cheers
amachon
Make sure you have correct APN telstra.internet
Kenski13
What is a APN TELSTRA !!!
Kenski13
SKU VML4030-200NAS
amachon
I already put it in my reply...You dont need anything else.
telstra.internet
Kenski13,
The VML4030-200NAS uses the Arlo Mobile subscription plan which is only available in the US. Take a look here: What Arlo Mobile service plans are available?
For a list of available providers for Arlo Go and Arlo Go models, take a look here: How can I tell who my Arlo Go service provider is?
Kenski13
So James there must be away to get this GO connected its a lot of money to throw in the BIN ??? ANY IDEAS !!!
Kenski13,
That Arlo Go model is not designed to work outside the US and can only be used with the Arlo Mobile subscription plan (US only).
Kenski13
So why was this  information not give out untill know ???  what am i to do with a $800 dollar Camera that wont work ??
amachon
JamesC,
I am not sure you have looked at what I have written. I am using an Arlo GO from the US with a Telstra sim.
It does not need a subscription.
If any one doesnt want theirs because it doesnt work I will take it off your hands.
Kenski13,
Each Arlo Go model is designed to work with a specific carrier. You can try editing the APN as suggested by amachon above to allow use of another SIM but this may not work in all cases. This can be done by navigating to Settings > My Devices > Arlo Go > APN Settings.
Kenski13
Hi James anychance you could walk me through how to do this ????
Kenski13,
At what point in the setup process are you experiencing an issue? Is the Telstra SIM you currently have already activated?
Kenski13
yes its active !!! tryed to re set device but every time it canot find the device !!!
Kenski13,
I recommend you contact the Arlo Support Team to further troubleshoot. You will find several methods of contact here: Arlo Support Team
Kenski13
all ready tried too many times & still waiting on a resolution ??????
mickus
Hey Kenski,
Any luck with this? I purchased the same model Arlo Go (SKU: VML4030-200NAS) about a year ago with the intention of roadtesting as a potentional cost effective solution to monitor my construction sites. I spent a bunch of time researching operating bands and tried Optus, Telstra, Vodaphone sims to no avail.
Have you had any further luck with this?
Cheers.
  • 27 Replies
  • 136878 Views
  • 3 Likes
  • 8 In Conversation
