- 2
Feeling like an idiot! I do not see this gray line for the siren button on the new update!!
Message 1 of 27
21,200
26 REPLIES 26
Retired_Member
Not applicable
2018-11-24
07:59 PM
Definitely not as easy as it was. With the latest update, when looking at my Go, it has an alarm button only in full screen mode. . When I push it, it asks if I’m sure then gives me the option for home base or my Go. Activating it isn’t a sure thing I had to push it a few times to trigger the alarm.
Message 26 of 27
3,853
Hi everyone,
I wanted to update everyone that you can now trigger the alarm for Arlo Go.
You can do this by going to "Devices" tab and pull down the gray bar (below Arlo) and choose "Alarm." Once you choose "Alarm," you will see the following screen shown below. After hitting "Yes", this will trigger the alarm; however, if you have more than one product that can trigger the alarm (Arlo Go or Base Station Pro), you will get the next pop-up screen asking which product you like to trigger the alarm.
- 2
Modes et règles
