ARLO GO Offline
On my 3rd Arlo Go now. 1st one damaged by recalled charger which I never got notified of recall. It had worked fine except for charging issues. 2nd camera would not charge from day 1 and after changing battery - would come online for a bit and then go offline for ~24-36 hours after firmware update. Reseating the battery would restore services, but only for about an hour and the behavior would repeat. Got a 3rd camera suspecting bad antenna or device on 2nd unit. 3rd camera worked fine upon first configuration - online and operational for several hours. Upgraded from 1.094 firmware to 1.096 and the offline behavior returned. Thinking back to second unit - the offline issues only cropped up after a firmware update on it as well. Are others have this issue? How can I get the firmware reverted to the 1.094 version?
jeff_f,
Firmware updates are pushed from the server automatically. There is currently not a way to revert back to a previous Firmware.
Modes et règles
