ARLO GO Offline
  • 1 Reply
  • 3173 Views
jeff_f
On my 3rd Arlo Go now.  1st one damaged by recalled charger which I never got notified of recall.  It had worked fine except for charging issues.  2nd camera would not charge from day 1 and after changing battery - would come online for a bit and then go offline for ~24-36 hours after firmware update.  Reseating the battery would restore services, but only for about an hour and the behavior would repeat.  Got a 3rd camera suspecting bad antenna or device on 2nd unit.  3rd camera worked fine upon first configuration - online and operational for several hours.  Upgraded from 1.094 firmware to 1.096 and the offline behavior returned.  Thinking back to second unit - the offline issues only cropped up after a firmware update on it as well.  Are others have this issue?  How can I get the firmware reverted to the 1.094 version?
ShayneS
jeff_f,
Firmware updates are pushed from the server automatically. There is currently not a way to revert back to a previous Firmware.
  • 1 Reply
  • 3174 Views
