  • 4 Replies
  • 2165 Views
Clayton66
2different Arlo go’s,,,
With 2different cell providers
AT&T and Verizon
Will both work on the same app on my at&t phone with Arlo app,,reason being,,I can get a refurbished a hell of a lot cheaper,,with the Verizon code on it ,, at&t is also getting kinda dumb to the whole Arlo go cameras,,where Verizon will b campatiable as far as the plan goes but there cameras are high
The app is carrier agnostic - you're just connecting to the Arlo servers which the cameras will already have done.
Clayton66
So you are saying that it will work correct
Yes.  You can use Go cameras with a mix of carriers, and the camera can use a different carrier than the phone,
Of course you do need good signal from whatever carrier(s) you use.
Clayton66
I appreciate your quick response,now I am gona give one of these refurbished ones a go I think from eBay for Verizon,,and just get a hook up from Verizon for the 1 or mayb 2 more cameras
  • 4 Replies
  • 2166 Views
