Arlo GO - Is there any plans top support USB-C / fast charge power banks
Hi There!
I'm struggling with my Arlo GO charging with external powerbank. My Arlo GO is located in boat and external 220V power is available only in harbor. As Arlo GO have only micro USB connector, but power banks doesn't support 9V.
I wonder why Arlo don't upgrade power connector to USB-C which allows up to 100W charging power and is more standard nowadays and also lot of powerbanks are available supporting fastcharge.
I would love to upgrade my Arlo GO for new model having that feature. Is there any plans for this?
Thanks, Kari
Haven't seen or heard anything that would lead me to think this will happen.
but read this... https://kb.arlo.com/1152208/What-is-Quick-Charge-and-why-does-my-Arlo-Pro-Wire-Free-or-Arlo-Go-camer...
You need the original adapter or a quallcom type charger that will put out 5 and 9v to charge the battery
a simple inverter from you onboard batteries would allow the adapter to be powerd
Is it possible to use a qualcomm powerbank as power source in freezing temperatures? Having problem with battery drain in the winter.
The powerbank likely isn't a problem but the ability to charge the camera battery would be due to the camera's protection of the battery in freezing temps. However, the powerbank will continue to power the camera with no issue other than the usual reduction of capacity from the colder temps.
@ArloGoVML4030: The Go will probably think it is connected to AC power. That will automatically enable some AC-only features - resulting in the powerbank draining pretty quickly.
I suggest trying this now (not waiting for freezing temps), and see how long the powerbank lasts.
An Arlo solar panel might be a better option. That will trickle-charge when the temps are high enough, and won't trigger any AC-only features.
Is it possible to remove the battery and run the camera with powerbank only?
Likely yes (assuming the powerbank can charge the Go in the first place). But that won't solve the power drain issue I mentioned above. The camera will still likely think it is connected to AC power.
Modes et règles
