  • 1 Reply
  • 692 Views
sherrewilliams
Is there a Go2 external battery charger - a battery base?  I don't want to bring the camera inside to have to charge it.  I just want to rotate the batteries, so I need an inside base/station to charge the battery.  thank you
The Go 2, Ultra, Ultra 2, Pro3 and Pro4 all use the same accessories.  This external charger is compatible:
And the XL battery is also used in the Go 2.
Note the orientation of the batteries in the charger allow the both the normal batteries and the longer XL batteries to be charged.
  • 1 Reply
  • 693 Views
