  • 4 Replies
  • 2271 Views
Cjpl
Hi! Is there any update for the Arlo Go 2 camera to let the camera automatically connect to mobile network when it’s been disconnected? I’m really tired of do this manually and the there is nothing wrong with the signal.
ShayneS
Who is the mobile carrier for this device? do you have your camera setup with wifi as well?
Cjpl
The mobile carrier is the Swedish operator 3. 4/5 coverage.  No Wi-Fi possibility.
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Cjpl
Thanks, already done that but no reply yet. Seems there are several others with the same problems with the Arlo Go 2. My question was if there will be an update to correct the issue with the camera don’t connect to the mobile network after a disconnection.
  • 4 Replies
  • 2272 Views
