As the title says, I think there should be an option so when animal movement is detected: the spotlight does not turn on. Or an option to simply clarify what triggers spotlight activation
MissMadeline,
While you can adjust what triggers a push notification within your Smart Notifications settings, there is currently no option to suppress spotlight triggers based on type of motion specifically. I will pass your feedback along to the development team.
