Mounting wing nut
  • 1 Reply
  • 1766 Views
KippHill
I just mounted 2 cameras and had difficulty with one of them. The wing nut that tights the camera into position won’t tighten well. The other camera mounted fine. Is there a trick I don’t know about or is my mount defective? Can I get a replacement if I need one?
I use a different mount and don't have issues - I can't comment about the supplied mount. Does the nut work propery without the camera installed?
  • 1 Reply
  • 1767 Views
