  • 2 Replies
  • 1566 Views
MJ125
Hi,
I've recently installed a Go 2 camera which is running on an LTE network. I've also installed an SD card for storing footage so it doesn't chew through data.
I don't recieve notifications of motion from the camera, my Pro 5s do.
I'm wondering if this is because of the SD card? I tried turning off local storage but still no notifications.
Any help/insight would be appreciated.
Cheers
Are there any recordings on the SD card? Do you have a subscription for the camera or are you trying to only use the card for recordings? Can you live view and manually record?
Have you checked that the camera is armed?  Look in the mode(s) you are using to confirm there is a rule for this camera.
  • 2 Replies
  • 1567 Views
