Go Camera LTE Transistions
  • 1 Reply
  • 1836 Views
Andrewjl
Hello all.
Apologies if I missed another post on this subject.
I am operating my new Go 2 camera on LTE data only.   There is no wifi available at this time.
I have already noted that if I remove the SIM  and then reinsert it I have to remove and re-connect the the camera into the Arlo app each time
Does anyone know if the data should run out via my provider as I have not topped up. Will I need to be available to re-connect the device again?  Or will it just pick up where it left off.
This would defeat its flexiblity if it had to be re-connected each time
Thanks Andrew
BrookeN
If the Go 2 camera runs out of data/LTE then the camera will go offline.. If you got more data to the SIM then ideally the Go 2 should go online automatically. Same with removing/re-inserting the SIM card, there's no need to remove/re-add the camera.. It should only pick up where it's left off..
BrookeN
  • 1 Reply
  • 1836 Views
