I have a go 2. The blue light will not come on. I thought it might be the battery so I got a new battery. I still can’t get a blue light or any light. Nothing.
Message 1 of 2
853
y default, the blue LED only shows when the camera is plugged into AC power and the battery is fully charged. You can change that in the camera settings. Click on the camera name section and check Indicator LED to see if that has been turned off.
