Is the Arlo Outdoor power adapter compatible with my Arlo Go 2 camera? I want to not use the battery when the weather is below 0 and plug it in to a power source.
You can find a list of compatible accessories within the Arlo Go 2 FAQ here: Arlo Go 2 LTE / WiFi Security Camera FAQs
I've updated the posts above to reflect the appropriate outdoor charging cable for Arlo Go 2.
I've also made a request for the web page to be updated to reflect this information.
@jguerdat wrote:Use this one:
https://www.arlo.com/en-us/accessories/VMA5600C-100NAS.html
@JamesC : can you clarify what charger is needed? BTW, the accessories page for shop.arlo.com doesn't have a filter for the Go 2. It'd be great if Arlo fixed that.
Thank you!
Is this a verified solution? Support has no idea what I am asking for. The solar panel does not provide enough power in cold weather. We want to plug the camera into electricity. is the VMA5600C-100NAS the solution?
Yes.
Sorry to be obtuse, StephenB, are you saying that the VMA5600C-100NAS terminates at one end magnetically to connect to the Go 2, and the other end terminates in a USB connector? And, the VMA5600C-100NAS comes with a charging block that plugs into standard electricity socket??
No, the outdoor charger is a sealed unit. There's a wall wart with a permanent sealed connection and a magnetic connector on the other. It plugs into any standard 120VAC outlet that has sufficient room to accommodate the size of the wall wart.
Update- Our battery has charged to 60% in a few hours, so this is a good adapter to use with electricity. I ordered mine on Amazon since Arlo was out of stock.
