  • 16 Replies
  • 7601 Views
  • 4 Likes
  • 7 In Conversation
vanderkat17
I just received a new Arlo Go 2 from Verizon, confirmed yesterday it is activated. I can make it through the entire setup process on the App until I have to name it and select a timezone. It errors our, "Error Occurred: something went wrong so your camera cannot be registered to your account please try again". Because I cannot get it to register, I am unable to get support because  I "don't have a subscription/device", EXCEPT I DO. I am extremely frustrated as I have not had  very good success trying to setup this simple camera since it was delivered last night.
16 REPLIES 16
vanderkat17,
Which app are you using (iOS or Android)? Do you have a different device you could try using to complete setup? Is the behavior the same?
vanderkat17
Hi, Thanks for responding!
I'm using the Apple Arlo app (iPhone 12), my iOS and Arlo app are both up to date. I've uninstalled and reinstalled the app as well as created a whole new Arlo account with a different email address with no success. I've also restarted my phone multiple times. I attached the error I keep seeing.....I get this both trying to "add device" via wifi and when adding as is via LTE/data.
Kathleen
vanderkat17,
I'll see what I can find out about this error. I will reach out to you in a private message to gather more informaiton.
vanderkat17
Thank you so much.
JeffMFA
Hi, I have a Go2 as well and cannot get it to connect at all. I've tried over wifi and over lte.  I reached out to our verizon rep and even ordered a new sim.  Both sims were confirmed activated and yet it still does not connect.  I have tried multiple devices to include, pc on the my.arlo.com site, iphone that is up to date along with the most recent version of the arlo app, and on my personal phone that is android with the most recent arlo app.  I really just need this to work for a customer.
JeffMFA,
Are you seeing an error message during onboarding? At what point do you experience the issue?
vanderkat17
I ended up getting a different camera and had zero problems, thus far.
gary234
i got the same issue. so trouble some!!!
gary234
when you go to the screen wher eyou name the camera, and set the time, and it says error occurred when continue is pressed, really cant be bothered going back to shop to replace, please if anyone can help
gary234,
Are you able to provide a screenshot of the error?
Aphillips
Did you get this issue resolved?
If so what did you do as I’m having the same issue? Thank you
HMCS
Having a similar issue. When I first go the camera I tested the Arlo Go 2 with my cell's sim to verify functionality. When I went to get another sim for the camera, I deleted the device to set it up again and was getting a registration error.
Following the instructions below helped me re-register the camera and its working perfectly at this point.
https://www.arlo.com/en_eu/support/faq/1202749/How-do-I-reset-my-Arlo-Go-camera-to-factory-default-s...
Aphillips,
A what point during onboarding are you experiencing an issue? Could you provide more details?
BSanders38
Please advise how to fix this issue. Goes fine until it gets to position the camera and it just keeps spinning. Have changed the SIMS card. Removed from app and everything else. Still not connected. Other 4 were fine
BSanders38
James C - can you advise what the solution to this problem is?  I have 5 cameras - 4 have worked perfectly and the 5th will not complete the set up no matter what I do.  It gets all the way to where you set the position of the camera and it never gives me a picture and that is as far as it goes.  Please advise the solution.
BSanders38,
Consider factory resetting the camera as detailed on page 71 here: https://www.arlo.com/en-us/images/pdf/Arlov4SupportDocs/ArloGo2/202-50035-01_Arlo_Go2_UM_29sep2021.p...
After the reset is complete, try onboarding again. Do you still experience the same behavior?
  • 16 Replies
  • 7601 Views
  • 4 Likes
  • 7 In Conversation
