Arlo Go 2 Wifi Reconnection
  • 5 Replies
  • 1013 Views
tamersradio6g
It seems from the support article (https://kb.arlo.com/000062618/How-to-select-between-Wi-Fi-or-Mobile-LTE-connection-for-Arlo-Go-2#:~:...) that my Arlo Go 2 camera should automatically reconnect to wifi from LTE once my router comes back online, but the Arlo Secure app does not have the 'Set as Default Connection' toggle available in the network connection menu like the article says, so my camera stays on LTE even with full wifi signal strength.
Is this option hidden somewhere else in the app, or does the camera need to be manually re-synced after wifi network interruption?
5 REPLIES 5
ShayneS
Hi @tamersradio6g
Thanks for The feedback. Let me look into this and I'll let you know what I find as soon as possible.
ShayneS
@tamersradio6g
Can you provide a screenshot of the missing setting/option?
tamersradio6g
ShayneS
Thanks, Let me look into this and I'll update you as soon as possible.
ShayneS
I have escalated your case & someone from support will be reaching out to you as soon as possible.
  • 5 Replies
  • 1014 Views
