Motion
  • 4 Replies
  • 1150 Views
Alex1b
How do I save the sensitivity for motion. Slide to 45 bit when I come back it’s back at 60 trying to stop false alarms.
Have you removed/reset/reinstalled as I suggested before? Here's the procedure:
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
That should have worked. Try rebooting the phone and reinstalling the app. If that doesn't help, remove the camera from your account and reinstall it which should clear out any weirdnesses.
BrookeN
@Alex1b are you still seeing this same behavior?
Alex1b
Works for about a day and reverts back to 60.
have signed out re installed app still a issue
  • 4 Replies
  • 1150 Views
