- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Go-2-QA-2021-04
- WiFi / LTE connection
Options
- Mark Question as New
- Mark Question as Read
If the Arlo Go 2 is connected to WiFi and the WiFi cuts out will it automatically switch to LTE coverage? Say for example it’s in the middle of recording on WiFi and then switches to LTE will it keep recording to the cloud or require a transition period between connections?
-Will this be able to connect to a base station as well for better connectivity to my other Arlo devices? Thanks.
Answer
0
Likes
If the connection is lost (WiFi or LTE) during a recording, the camera will need to establish a new connection (WiFi or LTE) to continue recording. After the connection is re-established, the camera will be available again for a new recording. For more information on this, take a look here: https://kb.arlo.com/000062598/What-are-the-benefits-of-connecting-my-Go-2-Camera-via-mobile-or-WiFi
Arlo Go 2 connects directly to a WiFi network or LTE connection. It is not designed to connect to a base station or SmartHub.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
