vmc2030 - setting up with a new router from verizon
  • 12 Replies
  • 3754 Views
pigsnout
I just got a new router from verizon and I think it it only has 5mgz. How can I get my camera to work with it?
@pigsnout wrote:
Huh. 2.4 does not come up as an option on my phone. My last router gave me a choice of hooking up with the 2 or the 5. Do you happen to know how I can force my phone to pick  show the 2.4 sign up?
Older routers provided different network names for each radio, but most newer routers use a single network name for all channels.
I don't own this router, but page 44 of the manual gives you a way to disable the 5 ghz radios.  If you do that, the phone will have to use 2.4 ghz.  https://www.verizon.com/supportresources/content/dam/verizon/support/consumer/documents/internet/fio...
You would then re-enable the radios after setup is complete.
@pigsnout wrote:
 I get the chime sound but the search step fails.
Two things to try before you start changing router settings:
  • Make sure you are selecting the Essential Spotlight camera when you add the device (assuming your camera has a spotlight).  If you select the wrong model, the onboarding will fail.
  • Try using a PC (browse to my.arlo.com) to add the camera.  That sometimes will succeed when the app fails.
12 REPLIES 12
Unlikely.  What router model?
pigsnout
vmc2030
pigsnout
essential vmc2030
What router did you get from verizon?
pigsnout
pigsnout
Maybe get verizon to swap my router is easiest solution.?
@pigsnout wrote:
model # G3100
That is  a triband router - with one 2.4 ghz radio and two 5 ghz radios.
So it does have 2.4 ghz wifi.
pigsnout
Huh. 2.4 does not come up as an option on my phone. My last router gave me a choice of hooking up with the 2 or the 5. Do you happen to know how I can force my phone to pick  show the 2.4 sign up? I get the chime sound but the search step fails.
pigsnout
Thank you so much for your time Stephan B! I really appreciate it.
pigsnout
Hi Stephen. I am all set up! I think I was choosing Essential instead of w/ spotlight. Thanks for the thought probes. - Andy
@pigsnout wrote:
I am all set up!
Great!
