- English
- Cameras
- my free trial has ended and I’m now not able to ac...
my free trial has ended and I’m now not able to access the recordings
Unfortunately, when I bought my cameras, I didn’t realise that I would have to pay extra to monitor them so I’m now in the position where my free trial has ended and I’m now not able to access the recordings although I have apparently thousands of them on the cloud which I’m unable to access without paying. I’m retired and it’s a consideration paying the amount that Arlo require per month for me to be able to monitor the recordings from my cameras. I also have no way of deleting all these recordings which are mounting up hugely on the cloud. Any suggestions or help advice would be very much appreciated.
The subscription cost is for the cloud storage itself (among other things), not for the ability to access the recordings.
When the trial(s) expired, the cloud recordings were automatically deleted. Also, no new recordings are being made, so none of your recordings are in the cloud anymore.
There is a feature in some of the smarthubs ("direct access to local storage") that some people use to avoid subscription costs. It would cost you about $100 USD to get a VMB4540 smarthub, plus another $20-$25 USD for a suitable USB thumb drive. The feature isn't as convenient as the subscription (it has a lot of limitations), so in my opinion it's not the best path.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
