essential spotlight not connecting to router
wire free spotlight light connected to router 3 units .purchased 2 essential spotlights initially connected direct router but low bandwith message so i doubled my internet plan removed essential cams tried to resync them and now essential does not resynch,chimes with q code ok ..then goes into searching for device and does not discover cameras..yes router 2.45
The low bandwidth issue is between the camera and router, not the ISP speeds. This implies blockage due to distance, number of walls in the signal path, stuff on/in the walls, house construction, etc. It can also be due to 2.4GHz wireless interference from other wireless devices. If bringing a camera closer to the router works fine, investigate these issues.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
