essential spotlight not connecting to router
  • 1 Reply
  • 2739 Views
chrisow
wire free spotlight light connected to router 3 units .purchased 2 essential spotlights initially connected direct router but low bandwith message so i doubled my internet plan removed essential cams tried to resync them  and now essential does not resynch,chimes with q code ok ..then goes into searching for device and does not discover cameras..yes router 2.45
The low bandwidth issue is between the camera and router, not the ISP speeds. This implies blockage due to distance, number of walls in the signal path, stuff on/in the walls, house construction, etc. It can also be due to 2.4GHz wireless interference from other wireless devices. If bringing a camera closer to the router works fine, investigate these issues.
