  • 8 Replies
  • 1891 Views
Reg4752
 The numbers don't go off the Arlo App after deleting the video's. I can turn the phone off and back on, but once a new video is recorded it shows the number and after deleting the number stays. How do I fix this?
8 REPLIES 8
ShayneS
Which version of the the mobile app are you using as well as the OS version on the Android phone?
Reg4752
Arlo version is 4.2.1_28524     Android version is 13
ShayneS
Can you try clearing your apps cache by performing the following? "Open Settings, and then swipe to and tap Apps. Select or search for the app you want to clear. Tap Storage, and then tap Clear cache."
Reg4752
I have done that, but I shouldn't have to do that every time. Once the videos have been deleted, the number should disappear automatically.
ShayneS
Does the number counter reset after reviewing the library tab?
Reg4752
No it doesn't. The only way to remove the numbers is to clear the data & cache, then I have to sign back into the Arlo account everytime.
ShayneS
Does this issue still occur on version 4.3.5 of the Arlo Secure mobile app?
Reg4752
My phone app shows version 4.3.5 and it shows 1 video, which there isn't any, so, yes it still occurs.
