- English
- Cameras
- Re: When my WiFi has outage & reconnects, my Arlo ...
When my WiFi has outage & reconnects, my Arlo base station/router won’t connect without being reset. The constant attempts by the 4 cameras we have to connect to the base station drains the battery. This just started happening 2 months ago.
Is the base connected directly to the router, or is it using a WiFi extender or mesh satellite?
Is it only the internet that is dropping? Or are you also getting a power glitch of some kind?
It’s hard to say because we are not there. But I would guess that it’s both.
Connected directly to base station/router with Ethernet.
Both meaning the WiFi went out due to electrical power going out for a bit.
if the power goes out, does the base station/router need to be manually reset? (Holding the button down for 10 seconds etc)
Of course a short power failure would also disrupt your internet. I am thinking that power glitches are more likely to be the cause.
There are a couple of approaches here.
Some folks have connected the base via a smart switch (Wemo or equivalent), which allows them to power-cycle the base remotely.
Others have put in a small UPS that keeps their base (and often their internet) running over short power failures.
Since I won’t know hen the power goes out, I believe I should try the ups. Do I plug just the Arlo Base Station/Router into the ups?
Yes. You can also plug in your main router (and cable modem if you have one).
It doesn't need to be very large - a 350VA UPS should be enough, as this equipment doesn't use that much power.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
