- English
- Cameras
- What camera do I have, the App says my 3 existing ...
I want to add to my VMB4000 home system that has 3 existing cameras. The online app says the cameras are H3 devices. I want to get 2 more of the same camera. Does anyone know what model the H3 is? I'm thinking they are Essential cameras.
Hx is the hardware revision of your model - not the model itself. Many cameras share the same H numbers, so you can't really tell the model from the Hs number.
What you can do is
- go into the support area of the app
- select the camera
- scroll to the bottom of the screen and look at the product info
- match the VMCxxxx number against the list here: https://www.arlo.com/en-us/support/docs
What you can do is
- select the camera
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
