This may be a faulty camera but first, remove the camera from your account. Hold the Sync button on the bottom for >15 seconds until the LED starts flashing amber. Let it reboot and add it back as if new. ANy difference?
Try a briefer sync press, like <1 second or at least a few variations.
You can try clicking on Continue anyways to see if the install will finish but I haven't had success doing so. Otherwise, start over after verifying that the camera doesn't show in your device list (remove it if it does) and doinng the reset procedure again.
I moved my Essential Spotlight Camera to a new home. I turned it off to not waste battery during the move.
Removed the device from the app in order to connect to the new wifi at the new place.
Now I can't turn it on in the app.
And when I try to connect, I don't get the blue light when I press the sync button, just an amber flashing light for a second or two.
I also tried resetting multiple times.
Perhaps it's because I haven't "turned on" the camera? Is there a way to do that outside the app? Or does the fact that the amber light comes on indicate that it is already "on"?
STM99,
Try charging the camera, the symptom you describe sounds like the battery is depleted.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
