- English
- Cameras
- Re: Spotlight light not coming on when motion dete...
When manually turned on works fine.
Current settings in “Low Light Settings” is:
Spotlight ON;
Colour OFF;
Behaviour CONSTANT;
Brightness 50%
It is connected to a base station.
I’m wondering if it’s because I do not have an active subscription. HOWEVER reading the user manual, it states “The Essential Spotlight Camera and Essential XL Spotlight Camera include an integrated spotlight. This spotlight is set to automatically turn on when your camera detects motion at night.” KBs also indicate that motion should trigger the light to come on, it does not state that it has to be recording which is a feature of the subscription. It means the spotlight should work when motion is detected, however it doesn’t.
I’ve tried to reset it, tried removing and re-adding, I’ve also tried adding via wifi vs base station.
How do I fix this? Or is this a bug?
I wonder if it's the color setting being off. I haven't tried that. The purpose of the spotlight is generally to get you enough light so you DO get color recordings at night.
I am experiencing the same issue.
We bought the two pack of the Arlo cameras, and one of them, the spotlight built into the camera works, but the other doesn't.
The Low Light Settings are below:
Spotlight ON;
Colour ON;
Behaviour CONSTANT;
Brightness 100%,
We previously had the brightness at both 95%, and 60%.
Is the camera that no longer works still have a subscription?
Hi Stephen,
Both cameras are still in the trial mode. Is there potential this could be interfering?
The spotlight should be coming on whenever the camera records or livestreams when it's too dark. The subscription matters, because the camera won't record to the cloud w/o a subscription (trial or paid).
There is a setting for the spotlight (video settings->low light settings). So the next step is to see if the cameras all have the spotlight feature turned on.
Because, my spot light also stopped working but I didn’t think it would be due to the trial ending
It can be. Though the spotlight should come on when livestreaming at night.
@Tony90 wrote:
However, no matter what low light setting I have with the spot light turned on, it doesn’t get triggered with motion automatically
I believe that is by design.
@TerryKingdom wrote:
I have a paid subscription now, and still nothing.
And this camera is in the subscription plan?
Also, check the rule for the camera, and make sure motion recording is still enabled there. https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Maybe also check that the spotlight is enabled in the low light settings.
That is unfortunate that even now with your paid subscription the motion detected spotlight doesn’t work. I was actually going to resubscribe or find a trial but after you experience will probably not.
Two out of many thousands/millions? If there's only 2 folks who have been unlucky enough to be bitten by this issue, it's hardly widespread or we would be inundated with complaints. It would seem to be faulty cameras so swapping at the store or using Settings, Support to get a replacement request started would be appropriate actions.
Same issue - after trial period the spotlight stopped working unless manually turned on or off. Previously, was able to adjust spotlight to turn on immediately if motion was detected but no longer an option. Pretty much makes the spotlight camera pointless and a waste of money b/c paid extra for the "spotlight" feature that I can't get the benefit of unless I purchase a subscription. Arlo in general has really disappointed over the last few years with hidden features being removed if not purchasing a subscription.
Side note, the video in my spotlight cameras will not save at all (I have two of them) while my Alro Pro 2 cameras both save videos on the cloud. Spotlight cams used to do this until trial period ended so I am assuming if no subscription then absolutely no saved videos? I don't get how it would not save the spotlight cameras but will for the Arlo Pro 2 cameras as none have a subscription.
Finally, the Arlo Baby Monitor is absolute trash. Arlo has ignored many of my complaints that others in the community have faced where a software update caused the camera to not be recognized/sync with the base making the camera unusable. This has been ongoing for over a year with no fix and Arlo admitting it was an issue they were working on. I'd like a refund as the product is not usable in any way.
Hi,
I have been reading your comment about the arlo spotlight camera and I have 2 spot light cameras that is having the same issue after my subscription ended...boohoo!!! Do you know is there a fix for this yet? Or did arlo fix this issue yet? Or refer to anyone who can help?
I honestly don’t know what happened but as soon as I posted and someone from ARLO responded to my post (or shortly thereafter).. my camera did a click or two and then it started acting correctly. 🤔🤔🤔 Super spooky!! I left it alone after that and it has been working ever since. Song short story long, I don’t know of the exact fix accept to complain. 🤷🏽♂️ I apologize.
@TerryKingdom , can we get them to reply to us in this forum and fix the same issue?
This is from Arlo team on the other chat forum similar to this...
"The spotlight is configured to engage for the duration of recordings. Without a subscription plan, the camera will not save recordings to the cloud but will still send a push notification for motion detection events. Simply detecting motion does not cause the spotlight to engage, it must also be recording."
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
