Searching for any available devices
  • 1 Reply
  • 1556 Views
BruB-55
I still cannot connect my cameras. I have completed all tips tricks and spend 90 minutes on the phone with support and still when it looks for the Arlo cameras they are not found. I have a wireless floodlight, doorbell, and outdoor camera that I am unable to connect.
I appreciate any further tips.
This is a user-to-user forum, so we have no idea what you've actually tried.
General advice on this
  • make sure the phone is connected to home wifi
  • disable any vpns
  • disable 5 ghz wifi in your router during onboarding if it will let you
  • remove any punctuation/special characters in the wifi network name and wifi password
  • double-check that the wifi security allows WPA2 (AES) connections
  • In the case of the Essential outdoor camera, make sure you are choosing the correct model (Essential Spotlight if it has a a spotlight)
Also, you can try onboarding everything but the doorbell from your browser (my.arlo.com) - that sometimes works when the app fails.
