Resolution reverting to minimum
I set the video resolution to 1536 x 1536. However every few days I go back to check as I don't believe I'm getting that full resolution, and I see it has often reverted to 720 x 720. Has anyone else noticed this?
Alongside another issue (separate thread) I'm having re short video duration I'm convinced the app isn't reflecting what is actually recording, and I wonder if this is somewhat intentional to reduce Arlo's cloud storage costs!
My suspicion is that the camera has a poor connection to your router or hub. In the past a poor connection could cause the resolution to temporarily change but I don't know if that's the case with newer cameras. A poor connection would also cause short duration videos due to a loss of adequate connection.
Another possibility is poor upload speeds through your ISP. What is your measured upload speed via speedtest.net?
I'm getting 15 down and 8 up at the front door. I haven't seen the resolution drop for a few days now
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
