  • 6 Replies
  • 3983 Views
JessicaOrtiz
I have added a new device and connected my camera. A few minutes later is disconnects and goes offline. What could the problem be? I have a arlo essential wire free charging camera outside.
Distance is only one possibility which is why I suggested moving the camera to see what happens. You could also swap cameras around to see if it's the camera or location.
6 REPLIES 6
Signal strenght/quality is likely the issue. Bring the camera closer to your router or hub to test.
JessicaOrtiz
I’ve had the cameras for a few months now and my other 2 are at the same distance as the third one and they are working great. Just one of them is disconnecting from the wifi.
JessicaOrtiz
I swapped 2 cameras around and they work perfectly fine. Thank you!!
Rochin
 that's my issue I have 4 others camera  and they work fine
  It's this floodlight
Details. All of them. What have you tried and what do you see?
