Not alerting in home mode
  • 11 Replies
  • 1904 Views
Cobra173
No alerts in home mode ! Ok with away modes
11 REPLIES 11
Did you go into the "armed home" mode, and check the rules in there?
Cobra173
yes checked the rules , still not activating
BrookeN
Are you still seeing this same behavior?
HerbieHollar
Yes, I am still getting NO alerts -- in ANY mode. No recordings to, except for manual ones.
BrookeN
HerbieHollar
Hi Brooke.
I've deleted modes and made new modes and I still get no notifications or recordings in my library when armed.
The link you referenced was for a different system. I found this one, https://kb.arlo.com/42, but I've done it all and no go.
Thanks, thought.
BrookeN
Can you tell me which of your cameras are seeing this behavior?
Cobra173
It was Arlo essential
Is your app showing you "Library" as a menu option?  Or is it showing you "Feed" and Dashboard" instead?
BrookeN
Our development team is aware of the behavior you are seeing and it is being looked into. As soon as there is an update I will reach out to the community.
HerbieHollar
I deleted, reset, and added 2 of my cameras to my system, and then the other 3 magically started working as well! Not sure what caused the others to begin working, but I'm glad! Unfortunately, I had deleted all of my custom modes as part of the troubleshooting process, so I had to painstakingly reprogram them all.
