Not alerting in home mode
@Cobra173 wrote:
No alerts in home mode ! Ok with away modes
Did you go into the "armed home" mode, and check the rules in there?
yes checked the rules , still not activating
Are you still seeing this same behavior?
Yes, I am still getting NO alerts -- in ANY mode. No recordings to, except for manual ones.
Did you check the settings under
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
Hi Brooke.
I've deleted modes and made new modes and I still get no notifications or recordings in my library when armed.
The link you referenced was for a different system. I found this one, https://kb.arlo.com/42, but I've done it all and no go.
Thanks, thought.
Can you tell me which of your cameras are seeing this behavior?
It was Arlo essential
Is your app showing you "Library" as a menu option? Or is it showing you "Feed" and Dashboard" instead?
Our development team is aware of the behavior you are seeing and it is being looked into. As soon as there is an update I will reach out to the community.
I deleted, reset, and added 2 of my cameras to my system, and then the other 3 magically started working as well! Not sure what caused the others to begin working, but I'm glad! Unfortunately, I had deleted all of my custom modes as part of the troubleshooting process, so I had to painstakingly reprogram them all.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
