I purchased two of these cameras less than two month ago and set them up one indoor and one outdoor.
However, the outdoor one stopped saving video clips a week ago (The indoor one is good). What’s worse, there is no option to set up active zone anymore (indoor one no issue). The detection seems fine as well.
I reset, remove and added back this device. No luck. The only thing I can do right now is live streaming.
Is this a software or hardware issue?
How can I fix it by myself?
Would I be eligible for a replacement?
At a glance it suggests that the trial subscription for the outside camera has ended.
Check under app settings/support/outside camera.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
