- English
- Cameras
- Multiple detections and recording segments of same...
Multiple detections and recording segments of same event
Ok. Guys. Since last firmware update I noticed that changes.
1. Multiple detections of same motion event.
2. Now recording segments of detected event limited with 10 seconds.
Here is difference. Before i had one event, one notification with length while motion is active, sometimes 1 minute or more.
Now I have 10 notifications with 10 separate recordings of same event.
Nice job guys.
Nice job guys.
Sounds like you're using "record while motion continues" - try using a timed recording. The camera decides when motion stops, not your eye. Maybe increasing motion sensitivity may help but the timed recording frequently just works better.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
