  • 1 Reply
  • 1203 Views
ROL-X
Ok. Guys. Since last firmware update I noticed that changes.
1. Multiple detections of same motion event.
2. Now recording segments of detected event limited with 10 seconds.
Here is difference. Before i had one event, one notification with length while motion is active, sometimes 1 minute or more.
Now I have 10 notifications with 10 separate recordings of same event.
Nice job guys.
Sounds like you're using "record while motion continues" - try using a timed recording. The camera decides when motion stops, not your eye. Maybe increasing motion sensitivity may help but the timed recording frequently just works better.
