Motion detected but no recording!!!
I’m starting to feeling that I didn’t make a good investment on my security system.
Please Arlo, need a solution!
Do you have a subscription for all cameras and are all activated in Settings, Subscription, Manage Cameras? Does your active mode have rules for the cameras that have the proper settings? Are you using zones and/or Smart notifications and are they set properly?
@piotostado wrote:
Since I’m in Mexico I can’t subscribe but there are only 4 cameras, think the limit for free is 5 cameras?
Unfortunately there is no free cloud storage for Pro 3 and Essential Cameras.
@piotostado wrote:
If I record locally is it possible? With a USB?
You can but on you VMB4000 base you posted you need to eject the USB and view it in a PC. If you get a Smarthub VMB4540 (USB) or VMB5000 (SD) you can view in the app but with limitations.
What is Direct Storage Access and how do I use it? (arlo.com)
How do I set up local storage backups on a USB device using my Arlo base station?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
