Model VMC2030 cant connect
Im using eero mesh network. i set it for 2.4 and have tried to link it several times with no success, made sure to set up with the spot light version and not just the essential. at a real lost of ideas i have tried using the app and my pc.
Also it stops blinking blue after couple seconds when i scan the QR not sure if that's normal.
If you have punctuation in the network name or password, try removing it.
The network security should be set to WPA2 (AES).
If you have beacons, then try turning those off. Also disable Eero Plus during onboarding.
changed the network name did nothing.. same as before blinks blue couple times after i scan the QR and hear the chime, then nothing.
i removed the beacon but still nothing
Are you auto filling the Network name or password? Can you try entering manually. Also, do you have dual bands active with your router? Can you try turning that off and connecting directly to the 2.4 band during setup. You can also try the web portal to onbaoard if you have not already.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
