Mode icon keeps disappearing in Arlo android app
  • 7 Replies
  • 3680 Views
Gordonius
Hi,
I am a new user on a 3 month free trial subscription.
Pixel 5, Android version 13. Arlo app version 3.6.9_28472
I notice that the MODE icon at the foot of the Arlo app keeps disappearing.  The DEVICES and LIBRARY icons never disappear.
I have found a work around to get the MODE icon back by going to settings/subscription/close and then return to the Arlo app home screen and the MODE icon reappears.
Any ideas in how to stop the MODE icon disappearing would be greatly appreciated. Thanks.
I normally see the Mode icon in maybe 15-ish seconds (never counted). Occasionally I have to force close the app when it gets stuck but that's not often. Have you rebooted the phone and reinstalled the app?
7 REPLIES 7
Normal operation for the app is to display Devices and Library quickly but Mode takes a while. How long have you waited? It sounds like you're just not waiting long enough.
Gordonius
Hi,
Thanks for your quick response.
The MODE icon has not reappeared since I created this post which is 12+ hours ago. I assume in normal operation the icon should appear in a few minutes, is that correct?
Thanks.
Gordonius
Hi,
I have rebooted my phone and the MODE icon is now consistently appearing (after about 5 seconds).
I will continue monitoring and if I see the problem again I will uninstall and reinstall the Arlo app as suggested.
For now I am happy to close this issue as solved.
Thank you for your support - greatly appreciated.
Xmastree
I'm having the same issue.
Can you please elaborate by what you mean by going to the Setting/Subscription/close? Are you closing the app or just going back to the devices?
Thank you!
Gordonius
Hi,
I meant just going back to DEVICES. Please note that this was just a work around and the problem kept reoccurring.
Since restarting my phone the problem has not reoccurred. So it turned out that a phone reboot was the permanent fix.
Hope that helps.
Xmastree
Thanks! Ill give it a try.
