- English
- Cameras
- Re: Last installed camera getting alerts but not r...
- 2
I am curious what update you are referring to?
App or Firmware?
My firmware updated on the base and only the EBay purchased camera (to my knowledge).
I would think there would be a warning to a camera needing Firmware updates
and you would need to approve.
@Madnmoshat wrote:
I have looked at your links. They do not apply to my situation. I am just into week 2 of my 3 month Arlo free trial. I have 3 Arlo Essential spotlight games and 1 floodlight camera. They were fine until after the last update. Last update, being the key words here. You don't seem to be able to help with my situation. I will just return them before my 30 days are up. Will not recommend Arlo.
You keep saying firmware update (witch may be possible) but you never actually Said as @StephenB suggested if you checked the subscription status or rules as sometimes glitch can move the subscription to inactive, same for rules. Also the question can you manual record.
@Madnmoshat The Manual record is in Live View steaming. It is the red button in the screen shot after you push it but white when not activated. See attached screen shot. No one replying here is from Arlo so we can't correct it. Again have you actually checked in your Subscription settings that the 3 month Trial is Active regardless you only had them for 2 weeks to eliminate that.
@Madnmoshat wrote:
If it had anything to do with a subscription they wouldn't have been working in the first place.
As @dcfox1 tried to explain, there are times when the cameras mysteriously shift out of their subscription. If that somehow happened, then it would explain your symptoms.
So I think you should check that with the app or my.arlo.com, and if it did happen to you, then you should contact support.
@Madnmoshat wrote:
How do I get to the manual record option?
You should see it when you are livestreaming. It's an icon in the bottom center of the image (a circle with a solid circle inside).
The question probes two potential issues
- subscription status (the control only shows up if the camera is under subscription)
- whether the problem is linked to the recording mode+rule, or not (if you can record manually, then the rule is the next place to look).
I understand that you are focussed on the app update (or maybe firmware) as the cause. But there are some other possibilities, and the suggestions I've made before are to rule those possibilities out (or alternatively zero on on a different cause that you could perhaps fix).
Please note................
From 2021-07-24 01:43 PM
@billrigsby wrote:
Note there is a bug in the Android app (the 3.5.1 update from 20 July). It won't show any local recordings at present.
That was a different issue, and was fixed in 3.5.2. @Madnmoshat is saying he isn't getting cloud recordings (and he should be still using his trial subscription). The bug in 3.5.1 didn't affect access to cloud recordings.
@Madnmoshat wrote:
I checked my subscription status and it's good until the end of October.
Good. The next step is to see if you can make a manual recording.
If you livestream the camera from my.arlo.com, you should see a recording control in the center bottom of the video. That will be a circle with a white solid circle in the center. There should also be a camera icon.
If you click on the camera icon, it should save a snapshot. If you click on the circle, the solid circle in the center should turn red - indicating it is recording.
Are you able to use those two features?
- 2
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
