- English
- Cameras
- Re: Last installed camera getting alerts but not r...
@billrigsby wrote:
. I know you do not need a subscription to record video
That's incorrect. All cameras launched after 2018 need a paid subscription for cloud recording. That includes Pro 3, Pro 4, Ultra, and Arlo Essential models.
What camera model did you purchase?
@billrigsby wrote:
Sorry I wasn't clear, I am recording to a USB drive, through the base station.
Thx for clarifying - then of course you should be seeing the recordings. Have you checked the rule for the camera?
Note there is a bug in the Android app (the 3.5.1 update from 20 July). It won't show any local recordings at present. So that might also be the problem (assuming a VMB4540 that has direct access to local storage configured).
@billrigsby wrote:
By 20 July I guess you mean July 20th of this year? That seems to be the version I have,
Yes. Are you using Android or iOS?
@billrigsby wrote:
I'm not sure what you mean by check the rule of the camera.
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Go into the "armed" mode, and look for a rule for the last camera. If there isn't one, then add it. If there is one, then make sure it includes the recording step.
@billrigsby wrote:
By 20 / July I guess you mean July 20th of this year? That seems to be the version I have, I'm not sure what you mean by check the rule of the camera. I have only had Arlos for about a month but the other four function fine. Can you be more specific about the rule of the camera?
He meant the rule for the camera under the active mode you have. Here is a link to explain. Make sure it is set to record like your others.
What are modes and rules and how does Arlo use them?
Edit: We were replying at the same time. Didn't mean to repeat.
Yes, I am on Android.
Okay thanks, I found it, back of garage is set to if motion is detected, record video and it is set to up to 300 seconds.
I reset it just for grins we'll see what happens, but all four cameras were set the same way.
Maybe it could be the camera who knows. Thanks for your help I'll play with it some more.
Thank you, no worries about repetition.
Are you looking for recordings on the app, or are you putting the USB drive in your PC?
You won't be able to see any local recordings in the app, until Arlo fixes the bug they introduced last week.
Okay so now I can see the recordings if I put the USB drive in my PC, thanks. However, how come I can see recordings on all of the other cameras? Is that because they still have the free trial running? And when the free trial runs out in <three months and the bug is not fixed I will not be able to see anything on the app is that how this is going to work?
The bug must extend to the app on the computer also because I cannot see any of the recordings from the last camera on my PCI there without using/removing the USB drive.
You can still see the cloud recordings of the cams in the App library for the cams still on the trial. The bug is just for viewing local recordings. I would think Arlo should have this bug fixed soon since it is so widespread with Android App.
@billrigsby wrote:
I cannot see any of the recordings from the last camera on my PC there without using/removing the USB drive.
You need a subscription to see them directly on the PC. You only have direct access to local storage in the app (which is broken at the moment).
Okay, thank you I'm getting the hang of all this, I'm only about two or three weeks in, so just call me the Newbie.
No problem, it does take a while to get it all sorted out.
It'd be good if Arlo could make it all a bit simpler.
@Madnmoshat wrote:
My camera's stopped recording and now only send notifications which are useless with no video.
Have you checked that they are still covered by the trial subscription?
You can use my.arlo.com for this. Go in to settings, and then select "subscription" from the left pane.
I replace them all with the Arlo Pro 3 cameras, so far things are working okay but I've also looking at other options.
I think this technology would have been good 10 to 15 years ago, Arlo seems like a company that just rested on its laurels and did not do any innovations, well with the exception of magnetic mounts.
We'll see how the pro 3s work, I still don't think the resolution is all that great maybe I'm expecting way too much for this caliber of a camera. Also looking at the eufy and Reolink systems as a backupplan. One good thing about Amazon free trial for a month and free returns.
@Madnmoshat wrote:
My subscription should be good.
Should being the key word.
I still recommend checking it, by going in the subscription area in the app or my.arlo.com.
If the subscription is active, then try making a manual recording, and seeing if that works. If it does, check that the active mode is telling the cameras to record. https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
If those steps don't help resolve it, then try support (using the link in the upper right of the forum page).
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
