- English
- Cameras
- Iphone 14 Pro unable to install base Stations
I bought an iPhone pro 14 Pro and tried to installed Arlo into it. To my surprise I am not able to install Base stations into it. I followed all the instructions with no success. I also notice that the new Arlo software icon look different. It is a round Black circle wit a house in the center. In my previous phone I had a bird in the icon. I wonder if the problem comes with the new software or the new iPhone.
The new arlo logo for the secure app changed with the v4 app update.
Arlo has also split the app in two directions, the original experience has remained the same and the new experience operates differently and requires you to rebuild your settings as well as being very buggy.
Best stick with the original experience until arlo sorts it out.
If you already had arlo working on your old phone, you would not need to rebuild on a new phone, just install the app and login with the same credentials.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
