How do i know if my router is 2.4 ghz or 5 ghz?
  • 1 Reply
  • 1805 Views
Ranger6
i just purchased the arlo essential wireless camera. How do i know if my router is 2.4 ghz or 5 ghz  my router has a 2.4 and 5 ghz light  will the cameras work
Then it has both bands.  The camera will use the 2.4 ghz channel.  You might find you need to disable the 5 ghz channel in your router settings when you onboard the camera.  If you do that, you can just re-enable it after you set up the camera.
