- English
- Cameras
- Re: Installing newer Essential Spotlight and Pro 4...
Has anyone else noticed (or tested, as I have begun) that after installing a few new cameras to supplement my EOL cams, the older EOL cams are much, MUCH less responsive? I fear that during the installation of the new Essential Spotlight and Pro 4 cams, when the app states that it's "searching for updates" for the base station, it's actually downloading some new software that dramatically slows down the older cams. I really wish that this was just my imagination, but my formerly whip-fast Pros (even just a couple of hours ago) now barely catch my movements. I actually had to stand in front of one camera and wave my hand within 12 inches of the camera's lens for about 15-20 seconds in order for the camera to trigger. I won't bore you with the several other examples of sluggery as that one is the most egregious. My cynical side is telling me that, now that we've purchased a couple of new cameras, Arlo is going to speed the demise of our old cameras, forcing us to upgrade all of our remaining ones. By slowing our old cameras after we bought new ones (rather than doing so soon after the July 1 EOL), they must figure that they're lessening the risk of us leaving Arlo altogether and losing the monthly/yearly cloud fees. Luckily I still have 15 days remaining to test more thoroughly before my Best Buy return window closes but I wanted to see if any other Arlo owners have experienced this as well. And if you haven't purchased new cameras yet, BEWARE, this may happen to you as well! I look forward to your replies -- thank you!
The base station, assuming it's always connected to the Internet, already has the latest firmware. The update process when installing a new camera that's being connected to the base is simply verifying that.
It's possible that the new camera is in a location that's somehow interfering with the signal to the old cameras. If you remove the new camera from your account or take the new camera out of range from the base, do the old cameras revert back to their previous behavior?
Thank you,
Did you remove ALL new cameras from your account to see what happens? If the new cameras are causing the problem, this should make it clear.
I had only installed one new camera (from the 4-pack) so after removing that camera from my account, yes, I had essentially removed "all" new cameras. Delayed recognition is still occurring. Curious, and one thing I haven't looked into yet, is there a way to revert back to the immediately-previous software version for the base station? I would think that could be a rather strong indicator about possible software update conflicts.
Thank you, jguerdat,
TJO
Only Arlo could provide a reverse update which AFAIK has only happened once. Besides, since the base firmware hasn't been updated since adding the new camera, it wouldn't matter. A brute force method to attempt a fix would be to remove ALL devices from your account and start fresh. I'm not sure it would help but maybe...
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
