The usual fix is to position the camera so it eliminates the street, etc. that aren't part of the protected area as well as to turn down the motion sensitivity in your modes and rules. Battery life is achieved by limiting recording and live viewing to >5 minutes per day as well as to have a decent connection to your router or hub.
https://kb.arlo.com/37/How-do-I-position-my-Arlo-wire-free-camera
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
its never facing the streets.
internet connection is good.
it needs charging every 3 days
Try removing activity zones (if you use them). Then see about how many minutes of recording you are getting between charges.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
