new systems installed last week ( 3 x spotlight, video door bel and hub.), hub is on channel 1 and strong ( pushing my router signal). Can I acces the hub to change name in stead of the standard, change wifi channel and check settings ?
You can not change the wifi network name or channel used by the hub - Arlo does not let you access any of the WiFi settings.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
